cgal-discuss - [cgal-discuss] Re: Mesh generation question
  • To:
  • Subject: [cgal-discuss] Re: Mesh generation question
  • Date: Sat, 28 Jan 2012 10:37:06 -0800 (PST)
Here is the code I'm using
int main()
// Create domain
Polyhedron polyhedron;
make_cube_3(polyhedron);
Mesh_domain domain(polyhedron);
// Get sharp features
domain.detect_features();
// Mesh criteria
Mesh_criteria criteria(edge_size = 25.0,
facet_angle = 15, facet_size = 15.0,
facet_distance = 0.05,
cell_radius_edge_ratio = 3, cell_size = 50.0);
// Mesh generation
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria);
std::cout << "Basic Mesh generated...\n";
// Insert points here
typedef C3t3::Triangulation Tr;
typedef Tr::Point Point_3;
std::vector<Point_3> plist;
std::vector<double> slist;
parse_input(plist, slist);
for(unsigned int i = 0; i < plist.size(); ++i){
Point_3 p = plist[i];
c3t3.triangulation().insert(Point_3(plist[i][0], plist[i][1],
plist[i][2]));
std::cout << "Total number of points inserted: " <<
c3t3.triangulation().number_of_vertices() << std::endl;
// Set tetrahedron size (keep cell_radius_edge), ignore facets
Mesh_criteria new_criteria(facet_angle=20.0, cell_radius_edge=3,
cell_size=125.0);
// Mesh refinement
CGAL::refine_mesh_3(c3t3, domain, new_criteria);
// Output
std::ofstream medit_file("out.mesh");
c3t3.output_to_medit(medit_file);
======================= I would like to not post my complete code in here,
but if you want, I can email you the complete code. Hope this helps in
nailing down the problem already.
Thanks,
--Ram
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-generation-question-tp4300233p4336602.html
