- To:
- Subject: Re: [cgal-discuss] Re: How to use CGAL Trang methods
- Date: Tue, 13 Mar 2012 11:45:07 +0300
so if I installed cmake-2.8.7 on a 64 bit machine it should work properly right??
On 13 March 2012 11:39, Andreas Fabri <> wrote:
yes it does.
The biggest problem people encounter on win64 is to compile boost.
andreas
On 13/03/2012 09:30, Sweety Pie wrote:
Just a small question: Does CMake work with win x64 bit?
On 12 March 2012 21:11, Sweety Pie <<mailto:>> wrote:
The GNU is for the Zlib thing to uncompress the files.
I will send you the txt file .Thank you very much for the help
Regards,
On 12 March 2012 21:03, Laurent Rineau (GeometryFactory)
<<mailto:>> wrote:
Le lundi 12 mars 2012 20:55:40 Sweety Pie a écrit :
> C:\Program Files (x86)\Microsoft Visual Studio
10.0\VC\bin\CL.exe /c
> /I"C:/Program Files (x86)/GnuWin32/include" /Zi /nologo /W3
/WX- /Od /Ob0
> /Oy- /D WIN32 /D _WINDOWS /D _CRT_SECURE_NO_DEPRECATE /D
> _SCL_SECURE_NO_DEPRECATE /D _CRT_SECURE_NO_WARNINGS /D
> _SCL_SECURE_NO_WARNINGS /D _DEBUG /D "CMAKE_INTDIR=\"Debug\""
/D _MBCS /Gm-
> /EHsc /RTC1 /MDd /GS /fp:strict /fp:except- /Zc:wchar_t
/Zc:forScope /GR
> /Fo"cmTryCompileExec.dir\Debug\\" /Fd"C:/Program Files
(x86)/CGAL-3.9/CMakeFiles/CMakeTmp/Debug/cmTryCompileExec.pdb"
/Gd /TP
> /analyze- /errorReport:queue
..\..\config\support\print_ZLIB_version.cpp
> /Zm1000
You compile using MSVC 2010, 32 bits version. But what is that
GnuWin32 stuff
and why is it in the include path?
Can you send me the generated CMakeCache.txt privately?
Laurent Rineau, PhD
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Re: How to use CGAL Trang methods, (continued)
- [cgal-discuss] Re: How to use CGAL Trang methods, ayongwust_sjtu, 03/10/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/10/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/12/2012
- [cgal-discuss] Re: How to use CGAL Trang methods, ayongwust_sjtu, 03/12/2012
- Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/12/2012
- Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/12/2012
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/12/2012
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/12/2012
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Andreas Fabri, 03/13/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/13/2012
- Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/13/2012
- Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/14/2012
