cgal-discuss - Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • To:
  • Subject: Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • Date: Tue, 13 Mar 2012 09:57:44 +0100
On 13/03/2012 09:49, Sweety Pie wrote:
so what issues do you faced with boost?
Boostconsulting provides precompiled boost for 32 bit Windows platforms
and for 64 bit you have to compile it yourself
The call looks something like this (You have to adapt it to your
version of the VC++).
bjam.exe --stagedir=stage64 address-model=64 toolset=msvc-10.0 --with-thread --with-date_time --with-program_options --with-filesystem --with-system --with-serialization debug release stage
andreas
On 13 March 2012 11:47, Andreas Fabri
<mailto:>>
wrote:
On 13/03/2012 09:45, Sweety Pie wrote:
so if I installed cmake-2.8.7 on a 64 bit machine it should
work properly right??
right. that's even exactly the version I use on my 64 bit machine.
andreas
On 13 March 2012 11:39, Andreas Fabri
<mailto:>
<mailto:
<mailto:>>>
wrote:
yes it does.
The biggest problem people encounter on win64 is to compile
boost.
andreas
On 13/03/2012 09:30, Sweety Pie wrote:
Just a small question: Does CMake work with win x64 bit?
On 12 March 2012 21:11, Sweety Pie
<mailto:>
<mailto:
<mailto:>>
<mailto:sweetyp198612@gmail.
<mailto:sweetyp198612@gmail.>____com
<mailto:
<mailto:>>>>
wrote:
The GNU is for the Zlib thing to uncompress the files.
I will send you the txt file .Thank you very much
for the help
Regards,
On 12 March 2012 21:03, Laurent Rineau (GeometryFactory)
<http://normalesup.org>
<mailto:
<mailto:>>
<>____normalesup.org
<mailto:
<mailto:>>>>
wrote:
Le lundi 12 mars 2012 20:55:40 Sweety Pie a écrit :
> C:\Program Files (x86)\Microsoft Visual Studio
10.0\VC\bin\CL.exe /c
> /I"C:/Program Files (x86)/GnuWin32/include" /Zi /nologo /W3
/WX- /Od /Ob0
> /Oy- /D WIN32 /D _WINDOWS /D _CRT_SECURE_NO_DEPRECATE /D
> _SCL_SECURE_NO_DEPRECATE /D _CRT_SECURE_NO_WARNINGS /D
> _SCL_SECURE_NO_WARNINGS /D _DEBUG /D "CMAKE_INTDIR=\"Debug\""
/D _MBCS /Gm-
> /EHsc /RTC1 /MDd /GS /fp:strict /fp:except- /Zc:wchar_t
/Zc:forScope /GR
> /Fo"cmTryCompileExec.dir\____Debug\\" /Fd"C:/Program Files
(x86)/CGAL-3.9/CMakeFiles/____CMakeTmp/Debug/____cmTryCompileExec.pdb"
/Gd /TP
> /analyze- /errorReport:queue
..\..\config\support\print_____ZLIB_version.cpp
> /Zm1000
You compile using MSVC 2010, 32 bits version.
But what
is that
GnuWin32 stuff
and why is it in the include path?
Can you send me the generated CMakeCache.txt
privately?
Laurent Rineau, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.____com/
<http://www.geometryfactory.__com/
<http://www.geometryfactory.com/>>
Release Manager of the CGAL Project
http://www.cgal.org/
https://lists-sop.inria.fr/____wws/info/cgal-discuss
<https://lists-sop.inria.fr/__wws/info/cgal-discuss>
<https://lists-sop.inria.fr/wws/info/cgal-discuss>>
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 <tel:%2B33.492.954.912>
<tel:%2B33.492.954.912> skype: andreas.fabri
Andreas Fabri, PhD
phone: +33.492.954.912 <tel:%2B33.492.954.912> skype: andreas.fabri
Andreas Fabri, PhD
phone: +33.492.954.912 skype: andreas.fabri
