cgal-discuss - Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • To:
  • Subject: Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • Date: Tue, 13 Mar 2012 11:49:25 +0300
so what issues do you faced with boost?
On 13 March 2012 11:47, Andreas Fabri <> wrote:
On 13/03/2012 09:45, Sweety Pie wrote:
so if I installed cmake-2.8.7 on a 64 bit machine it should
work properly right??
right. that's even exactly the version I use on my 64 bit machine.
andreas
On 13 March 2012 11:39, Andreas Fabri <
<mailto:>> wrote:
   yes it does.
   The biggest problem people encounter on win64 is to compile boost.
   andreas
   On 13/03/2012 09:30, Sweety Pie wrote:
       Just a small question: Does CMake work with win x64 bit?
       On 12 March 2012 21:11, Sweety Pie <
       <mailto:>
       <mailto:__com
       <mailto:>>> wrote:
           The GNU is for the Zlib thing to uncompress the files.
           I will send you the txt file .Thank you very much for the help
           Regards,
           On 12 March 2012 21:03, Laurent Rineau (GeometryFactory)
       <laurent.rineau__CGAL@__normalesup.org
       <mailto:>
       <mailto:__normalesup.org
       <mailto:>>> wrote:
               Le lundi 12 mars 2012 20:55:40 Sweety Pie a écrit :
        > C:\Program Files (x86)\Microsoft Visual Studio
               10.0\VC\bin\CL.exe /c
        > /I"C:/Program Files (x86)/GnuWin32/include" /Zi /nologo /W3
               /WX- /Od /Ob0
        > /Oy- /D WIN32 /D _WINDOWS /D _CRT_SECURE_NO_DEPRECATE /D
        > _SCL_SECURE_NO_DEPRECATE /D _CRT_SECURE_NO_WARNINGS /D
        > _SCL_SECURE_NO_WARNINGS /D _DEBUG /D "CMAKE_INTDIR=\"Debug\""
               /D _MBCS /Gm-
        > /EHsc /RTC1 /MDd /GS /fp:strict /fp:except- /Zc:wchar_t
               /Zc:forScope /GR
        > /Fo"cmTryCompileExec.dir\__Debug\\" /Fd"C:/Program Files
         (x86)/CGAL-3.9/CMakeFiles/__CMakeTmp/Debug/__cmTryCompileExec.pdb"
               /Gd /TP
        > /analyze- /errorReport:queue
               ..\..\config\support\print___ZLIB_version.cpp
        > /Zm1000
               You compile using MSVC 2010, 32 bits version. But what
       is that
               GnuWin32 stuff
               and why is it in the include path?
               Can you send me the generated CMakeCache.txt privately?
               Laurent Rineau, PhD
               R&D Engineer at GeometryFactory
       http://www.geometryfactory.__com/ <http://www.geometryfactory.com/>
       https://lists-sop.inria.fr/__wws/info/cgal-discuss
       <https://lists-sop.inria.fr/wws/info/cgal-discuss>
   Andreas Fabri, PhD
   Chief Officer, GeometryFactory
   Editor, The CGAL Project
   phone: +33.492.954.912 <tel:%2B33.492.954.912>    skype: andreas.fabri
Andreas Fabri, PhD
phone: +33.492.954.912    skype: andreas.fabri
