cgal-discuss - Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • To:
  • Subject: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • Date: Wed, 14 Mar 2012 21:46:55 +0300
Installing it directly on C;\ just didn't work :(
On 14 March 2012 15:19, Sweety Pie <> wrote:
I will try to uninstall CGAL and install it directly into C:\
I didn't find a log file in the mentioned location. :(
Will let you know the results after I install it in the new location.
On 14 March 2012 12:29, Laurent Rineau (GeometryFactory) <> wrote:
Le mercredi 14 mars 2012 12:17:22 Sweety Pie a écrit :
> Thanx for the reply.
> I have read in a tutorial that source and binaries should indicate the same
> location. However, I just created a new folder in another location now for
> the binaries and tried but still the same error happened. It was working
> before on the same directory but I really don't know what happened.
> Any other ideas will be appreciated.
> Thanx for all
Other CMake users have that issue. See
http://public.kitware.com/Bug/view.php?id=11967
Can you post the full error message? The one you posted says "there is a
failure" without any more precision?
Maybe you should try to install CGAL-3.9 directory into C:/ instead of
C:/Program Files*/. In the past I saw strange message from CMake because of
the parenthesis in the name of "C:/Program Files (x86)/".
Have also a look to the files C:/Program Files(x86)/CGAL-3.9/CMakeFiles/CMakeTmp/. There may be a log file.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
