cgal-discuss - Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • To:
  • Subject: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • Date: Wed, 14 Mar 2012 10:12:59 +0100
Le mardi 13 mars 2012 23:15:28 Sweety Pie a écrit :
> I have re-installed CGAl but this time it is giving this message in CMake:
> CMake Error at C:/Program Files (x86)/CMake
> 2.8/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:52 (MESSAGE):
> The C compiler "cl" is not able to compile a simple test program.
> It fails with the following output:
> Change Dir: C:/Program Files (x86)/CGAL-3.9/CMakeFiles/CMakeTmp
> Run Build
> Command:C:\Windows\Microsoft.NET\Framework\v4.0.30319\MSBuild.exe
> cmTryCompileExec.vcxproj /p:Configuration=Debug
> Please help . Am really stuck :(
Do not use "C:/Program Files (x86)/CGAL-3.9" as binary directory. In CMake,
you can use that directory as source directory, but use a separate directory,
not in C:/Program Files*/ as binary directory.
Laurent Rineau, PhD
