- To:
- Subject: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
- Date: Wed, 14 Mar 2012 12:17:22 +0300
Thanx for the reply.
I have read in a tutorial that source and binaries should indicate the same location. However, I just created a new folder in another location now for the binaries and tried but still the same error happened. It was working before on the same directory but I really don't know what happened.
Any other ideas will be appreciated.
Thanx for all
On 14 March 2012 12:12, Laurent Rineau (GeometryFactory) <> wrote:
Le mardi 13 mars 2012 23:15:28 Sweety Pie a écrit :
> I have re-installed CGAl but this time it is giving this message in CMake:Do not use "C:/Program Files (x86)/CGAL-3.9" as binary directory. In CMake,
> CMake Error at C:/Program Files (x86)/CMake
> 2.8/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:52 (MESSAGE):
> The C compiler "cl" is not able to compile a simple test program.
> It fails with the following output:
> Change Dir: C:/Program Files (x86)/CGAL-3.9/CMakeFiles/CMakeTmp
> Run Build
> Command:C:\Windows\Microsoft.NET\Framework\v4.0.30319\MSBuild.exe
> cmTryCompileExec.vcxproj /p:Configuration=Debug
> Please help . Am really stuck :(
you can use that directory as source directory, but use a separate directory,
not in C:/Program Files*/ as binary directory.
Laurent Rineau, PhD
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, (continued)
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Andreas Fabri, 03/13/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/13/2012
- Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/13/2012
- Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/14/2012
- Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/14/2012
- Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/14/2012
- Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/14/2012
- Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/15/2012
- Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/15/2012
- Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/15/2012
- Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/16/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Andreas Fabri, 03/16/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/16/2012
