- To:
- Subject: Re: [cgal-discuss] Re: How to use CGAL Trang methods
- Date: Tue, 13 Mar 2012 21:25:11 +0100
My guess is that you run cmake in a shell or a Windows
command prompt which does not have cl.exe (that is the compiler)
in the PATH.
Start-> All Programs -> Microsoft Visual Studio 2010 -> Visual Studio Tools -> Visual Studio Command Prompt
gives you the right command prompt.
In case you use cygwin add
@echo Setting environment for using Microsoft Visual Studio 2008 tools.
@call "c:/Program Files (x86)/Microsoft Visual Studio 9.0/VC/vcvarsall.bat" amd64
to cygwin.bat
andreas
On 13/03/2012 21:15, Sweety Pie wrote:
I have re-installed CGAl but this time it is giving this message in CMake:
CMake Error at C:/Program Files (x86)/CMake
2.8/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:52 (MESSAGE):
The C compiler "cl" is not able to compile a simple test program.
It fails with the following output:
Change Dir: C:/Program Files (x86)/CGAL-3.9/CMakeFiles/CMakeTmp
Run Build Command:C:\Windows\Microsoft.NET\Framework\v4.0.30319\MSBuild.exe
cmTryCompileExec.vcxproj /p:Configuration=Debug
Please help . Am really stuck :(
On 13 March 2012 20:02, Laurent Rineau (GeometryFactory)
<mailto:>>
wrote:
Le mardi 13 mars 2012 19:54:27 Sweety Pie a écrit :
> Thank you very much for this. Your help is appreciated. This CGAL is
> driving me Crazy :(
> Somehow the CGAL folder has just disappeared from my disc and I
don't know
> how!!!!!
> Am installing CGAL 3.9 again but I wanted to know something. I
have done
> the installation a bit while ago so just to double check. Am
using Win7 x64
> bit machine so when I install CGAL if I choose the 32 bit option
is it
> going to work fine? since the boost thingy won't trouble me if I
choose 32.
That is all right. You can compile 32 bits programs on a x64
Windows. Make
sure you do install or compile 32 bits binaries of all dependencies.
Laurent Rineau, PhD
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, (continued)
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Andreas Fabri, 03/13/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/13/2012
- Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/13/2012
- Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/14/2012
- Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/14/2012
- Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/14/2012
- Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/14/2012
- Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/15/2012
- Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/15/2012
- Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/15/2012
