cgal-discuss - [cgal-discuss] Error in CMake Configuration
  • To:
  • Subject: [cgal-discuss] Error in CMake Configuration
  • Date: Tue, 17 Apr 2012 17:39:10 +0300
Dear all,
Can you please check the following errors am getting while configuring the Cmake with VS10 to compile the CGAL libraries:
_
CMake Error at cmake/modules/FindBoost.cmake:515 (FILE):
file Internal CMake error when trying to open file: C:/Program Files
(x86)/boost/boost/version.hpp for reading.
Call Stack (most recent call first):
cmake/modules/CGAL_SetupBoost.cmake:12 (find_package)
cmake/modules/CGAL_SetupDependencies.cmake:32 (include)
CMakeLists.txt:422 (include)
CMake Error at cmake/modules/FindBoost.cmake:528 (MATH):
math cannot parse the _expression_: " / 100000": syntax error, unexpected
exp_DIVIDE, expecting exp_OPENPARENT or exp_NUMBER (2)
CMake Error at cmake/modules/FindBoost.cmake:529 (MATH):
math cannot parse the _expression_: " / 100 % 1000": syntax error, unexpected
CMake Error at cmake/modules/FindBoost.cmake:530 (MATH):
math cannot parse the _expression_: " % 100": syntax error, unexpected
exp_MOD, expecting exp_OPENPARENT or exp_NUMBER (2)
CMake Error at cmake/modules/FindBoost.cmake:917 (message):
Unable to find the requested Boost libraries.
Boost version: ..
Boost include path: C:/Program Files (x86)/boost
The following Boost libraries could not be found:
boost_thread
No Boost libraries were found. You may need to set Boost_LIBRARYDIR to the
directory containing Boost libraries or BOOST_ROOT to the location of
Boost.
Thank you
