- To:
- Subject: Re: [cgal-discuss] Re: Error in CMake Configuration
- Date: Mon, 23 Apr 2012 17:47:20 +0200
Le lundi 23 avril 2012 08:35:05 cvoss a écrit :
> I'm having the same issues as the post right above this.
> Looking at this part:
> *CMake Error at C:/Program Files (x86)/CMake
> 2.8/share/cmake-2.8/Modules/Qt4Macros.cmake:111 (FILE):
> file Internal CMake error when trying to open file: C:/Program Files
> (x86)/CGAL-4.0/demo/C:/Program Files
> (x86)/CGAL-4.0/demo/AABB_tree/MainWindow_moc.cpp_parameters for writing.*
> It looks like the path to write to is mixed up, with the first several
> levels doubled. Any suggestion and how to correct this?
I have already said that you should never try to use something inside C:
\Program Files*\ as binary directory for CMake.
Keep CGAL sources in C:/Program Files (x86)/ but use something in your user
Document directory as binary directory.
Same for you, "Sweety Pie".
Laurent Rineau, PhD
- [cgal-discuss] Error in CMake Configuration, Sweety Pie, 04/17/2012
- Re: [cgal-discuss] Error in CMake Configuration, Laurent Rineau (GeometryFactory), 04/17/2012
- Re: [cgal-discuss] Error in CMake Configuration, Zoltán Váradi, 04/17/2012
- Re: [cgal-discuss] Error in CMake Configuration, Jasmin Formont, 04/17/2012
- Re: [cgal-discuss] Error in CMake Configuration, Sweety Pie, 04/21/2012
- [cgal-discuss] Re: Error in CMake Configuration, cvoss, 04/23/2012
- Re: [cgal-discuss] Re: Error in CMake Configuration, Laurent Rineau (GeometryFactory), 04/23/2012
- [cgal-discuss] Re: Error in CMake Configuration, cvoss, 04/24/2012
- Re: [cgal-discuss] Re: Error in CMake Configuration, Laurent Rineau (GeometryFactory), 04/24/2012
- [cgal-discuss] Re: Error in CMake Configuration, cvoss, 04/25/2012
- Re: [cgal-discuss] Re: Error in CMake Configuration, Sweety Pie, 04/29/2012
