- To:
- Subject: Re: [cgal-discuss] Error in CMake Configuration
- Date: Tue, 17 Apr 2012 17:14:12 +0200
I had this problem too, setting BOOST_ROOT was not enough, I had to set BOOST_LIBDIR to make Cmake happy.
2012/4/17 Zoltán Váradi <>
"No Boost libraries were found. You may need to set Boost_LIBRARYDIR to the
directory containing Boost libraries or BOOST_ROOT to the location of
Boost."
As it says, you should set the Boost_LIBRARYDIR or BOOST_ROOT in your path.This tutorial tells you how:http://geekswithblogs.net/renso/archive/2009/10/21/how-to-set-the-windows-path-in-windows-7.aspx
2012. április 17. 16:49 Laurent Rineau (GeometryFactory) írta, <>:
Le mardi 17 avril 2012 17:39:10 Sweety Pie a écrit :
> Dear all,Do you have a file "C:/Program Files (x86)/boost/boost/version.hpp"?
> Can you please check the following errors am getting while configuring the
> Cmake with VS10 to compile the CGAL libraries:
> _
> CMake Error at cmake/modules/FindBoost.cmake:515 (FILE):
> file Internal CMake error when trying to open file: C:/Program Files
> (x86)/boost/boost/version.hpp for reading.
If the CMake cache, do you have anything about Boost?
Laurent Rineau, PhD
- [cgal-discuss] Error in CMake Configuration, Sweety Pie, 04/17/2012
- Re: [cgal-discuss] Error in CMake Configuration, Laurent Rineau (GeometryFactory), 04/17/2012
- Re: [cgal-discuss] Error in CMake Configuration, Zoltán Váradi, 04/17/2012
- Re: [cgal-discuss] Error in CMake Configuration, Jasmin Formont, 04/17/2012
- Re: [cgal-discuss] Error in CMake Configuration, Sweety Pie, 04/21/2012
- [cgal-discuss] Re: Error in CMake Configuration, cvoss, 04/23/2012
- Re: [cgal-discuss] Re: Error in CMake Configuration, Laurent Rineau (GeometryFactory), 04/23/2012
- [cgal-discuss] Re: Error in CMake Configuration, cvoss, 04/24/2012
- Re: [cgal-discuss] Re: Error in CMake Configuration, Laurent Rineau (GeometryFactory), 04/24/2012
- [cgal-discuss] Re: Error in CMake Configuration, cvoss, 04/25/2012
- Re: [cgal-discuss] Re: Error in CMake Configuration, Sweety Pie, 04/29/2012
