cgal-discuss - Re: [cgal-discuss] Re: Error in CMake Configuration
  • To:
  • Subject: Re: [cgal-discuss] Re: Error in CMake Configuration
  • Date: Sun, 29 Apr 2012 09:50:48 +0300
cvoss,
How did you installed the CGAL sources in the user directory??
On 25 April 2012 23:14, cvoss <> wrote:
Laurent,
I'm using Cmake-gui 2.8.7.  I am on Win7 using VC10, compiling for 32-bit.
I was able to get past that error by using your suggestion to install the
source code in my user directory, instead.  Now I am able to generate the
build files and compile.  Actually, I'm having a linking issue with
CGAL_Qt3, but I'll start a new thread on that, if I can't figure it out.
cvoss
Laurent Rineau (GeometryFactory) wrote
> Le mardi 24 avril 2012 06:01:00 cvoss a écrit :
>> I saw that and did switch my binaries directory to
>> C:/User/MyName/Documents/CGAL, but I'm still having the same issue:
>> *Internal CMake error when trying to open file:
>>   C:/Users/MyName/Documents/CGAL/demo/C:/Program Files
>>   (x86)/CGAL-4.0/demo/Triangulation_3/Viewer.moc_parameters for writing.*
>> I've deleted the cache file, and actually even deleted and reinstalled
>> the
>> CGAL source code to try to eliminate any residual settings that would
>> have
>> been messed up by initially having the binary directories set to Program
>> Files (x86), but still get the same error.
> OK. That is interesting. Please give us your CMake version numbers. We
> will
> try to reproduce and understand that bug.
> What Microsoft Windows version do you use? As for the compiler you said
> VC10.
> In the mean time, you can try to install the sources of CGAL in you user
> directory too.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
> Release Manager of the CGAL Project       http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Error-in-CMake-Configuration-tp4564931p4587929.html
