cgal-discuss - Re: [cgal-discuss] Re: Error in CMake Configuration
  • To:
  • Subject: Re: [cgal-discuss] Re: Error in CMake Configuration
  • Date: Tue, 24 Apr 2012 15:39:03 +0200
Le mardi 24 avril 2012 06:01:00 cvoss a écrit :
> I saw that and did switch my binaries directory to
> C:/User/MyName/Documents/CGAL, but I'm still having the same issue:
> *Internal CMake error when trying to open file:
> C:/Users/MyName/Documents/CGAL/demo/C:/Program Files
> (x86)/CGAL-4.0/demo/Triangulation_3/Viewer.moc_parameters for writing.*
> I've deleted the cache file, and actually even deleted and reinstalled the
> CGAL source code to try to eliminate any residual settings that would have
> been messed up by initially having the binary directories set to Program
> Files (x86), but still get the same error.
OK. That is interesting. Please give us your CMake version numbers. We will
try to reproduce and understand that bug.
What Microsoft Windows version do you use? As for the compiler you said VC10.
In the mean time, you can try to install the sources of CGAL in you user
directory too.
Laurent Rineau, PhD
