cgal-discuss - [cgal-discuss] 3D demos when run gives segmentation fault
  • To:
  • Subject: [cgal-discuss] 3D demos when run gives segmentation fault
  • Date: Tue, 25 Jul 2017 03:43:09 -0700 (PDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23: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
I installed CGAL. My 2D demos work fine. 3D demos "make" works fine, no
errors. But when its run, it gives segmentation fault
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-demos-when-run-gives-segmentation-fault-tp4662856.html
