- To:
- Subject: Re: [cgal-discuss] 3D demos when run gives segmentation fault
- Date: Tue, 25 Jul 2017 13:59:21 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
On 07/25/2017 01:34 PM, neeta wrote:
CGAL 4.10 was used. I'm using ubuntu 16.04 and have installed QT5.6,
libQGLViewer-2.6.4.
My question is whether libQGLViewer was compiled with Qt4 or Qt5. If you call ldd on the libQGLViewer.so, you should see whether it is linked
with Qt4 or Qt5.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-demos-when-run-gives-segmentation-fault-tp4662856p4662861.html
- [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/25/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/25/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, Sebastien Loriot (GeometryFactory), 07/25/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/26/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/31/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, Sebastien Loriot (GeometryFactory), 07/31/2017
