- To:
- Subject: Re: [cgal-discuss] 3D demos when run gives segmentation fault
- Date: Tue, 25 Jul 2017 04:50:56 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
It is linked with QT4. All .so files as of the form "libQGLViewer-qt4.so"
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-demos-when-run-gives-segmentation-fault-tp4662856p4662863.html
- [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/25/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/25/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, Sebastien Loriot (GeometryFactory), 07/25/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/26/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/31/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, Sebastien Loriot (GeometryFactory), 07/31/2017
