cgal-discuss - Re: [cgal-discuss] 3D demos when run gives segmentation fault
  • To:
  • Subject: Re: [cgal-discuss] 3D demos when run gives segmentation fault
  • Date: Mon, 31 Jul 2017 13:54:27 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
On 07/31/2017 06:51 AM, neeta wrote:
Please help. Any solution?
I know there are some issues with libQGLViewer 2.7, you should try using an earlier version.
Also, when you report that something is not working, you should precise
what you've done otherwise we can only guess.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-demos-when-run-gives-segmentation-fault-tp4662856p4662869.html
