cgal-discuss - Re: [cgal-discuss] 3D demos when run gives segmentation fault
  • To:
  • Subject: Re: [cgal-discuss] 3D demos when run gives segmentation fault
  • Date: Tue, 25 Jul 2017 14:22:08 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
On 07/25/2017 01:50 PM, neeta wrote:
It is linked with QT4. All .so files as of the form "libQGLViewer-qt4.so"
You need to compile libQGLViewer yourself using qt5. Simply follow the isntructions here:
http://libqglviewer.com/installUnix.html#linux
and make sure the qmake used is the one from qt5
You'll need to reconfigure and recompile the 3D demos.
See here how to pass to cmake the libqglviewer you just compiled:
http://doc.cgal.org/latest/Manual/installation.html#title55
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-demos-when-run-gives-segmentation-fault-tp4662856p4662863.html
