- To:
- Subject: Re: [cgal-discuss] 3D demos when run gives segmentation fault
- Date: Tue, 25 Jul 2017 04:34:38 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
CGAL 4.10 was used. I'm using ubuntu 16.04 and have installed QT5.6,
libQGLViewer-2.6.4.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-demos-when-run-gives-segmentation-fault-tp4662856p4662861.html
- [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/25/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/25/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, Sebastien Loriot (GeometryFactory), 07/25/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/26/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/31/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, Sebastien Loriot (GeometryFactory), 07/31/2017
