- From: Benjamin Werner <benjamin.werner AT polytechnique.fr>
- To: Conor McBride <ctm AT cs.nott.ac.uk>
- Cc: Study group on Mechanized Metatheory for the Masses <provers AT lists.seas.upenn.edu>, coq-club AT pauillac.inria.fr, Steve Zdancewic <stevez AT cis.upenn.edu>
- Subject: Re: [Coq-Club] Extensional Equality for Function Types
- Date: Thu, 10 Feb 2005 23:21:44 +0100
Hi,
Correspondingly, there's no way you can construct a predicate
P on functions such that P f is inhabited and P g is empty when f and g
agree on all arguments: the only thing P can do with its function is
apply it.
Actually you can construct such a predicate. You will be able to exhibit a proof of P f. It will also be true that there is no closed proof of P g. However, you will not be able to prove this last statement inside the system; you can only convince yourself that it is true by using again an argument of the form "if I had a closed proof, then this proof would have to be of the form ... and this is not possible since ... and ... are not convertible".
If I am too obscure here, I can try to elaborate when I have a little more time.
Cheers,
Benjamin
- [Coq-Club] Extensional Equality for Function Types, Steve Zdancewic
- Re: [Coq-Club] Extensional Equality for Function Types,
Conor McBride
- Re: [Coq-Club] Extensional Equality for Function Types, Benjamin Werner
- Re: [Coq-Club] Extensional Equality for Function Types, Conor McBride
- Re: [Coq-Club] Extensional Equality for Function Types, Haixing Hu
Xavier Leroy
Jason Hickey
jean-francois . monin
Jason Hickey
roconnor
Conor McBride
- Re: [Coq-Club] Extensional Equality for Function Types, Jason Hickey
- Re: [Coq-Club] Extensional Equality for Function Types, Frederic Blanqui
Conor McBride
roconnor
Jason Hickey
Jason Hickey
Conor McBride
