- To: Steve Zdancewic <stevez AT cis.upenn.edu>
- Cc: coq-club AT pauillac.inria.fr, Study group on Mechanized Metatheory for the Masses <provers AT lists.seas.upenn.edu>
- Subject: Re: [Coq-Club] Extensional Equality for Function Types
- Date: Fri, 11 Feb 2005 11:45:47 +0100
> Is there a technical reason why there is no extensional equality
> principle for function types? The base library has surjective pairing
> for products, but nothing like this axiom:
> Axiom extensionality : forall (A:Set) (B:Set) (f:A->B)(g:A ->B),
> (forall x:A, f x = g x) -> f = g.
> Connor McBride's recent post (in the thread "Cannot Rewrite Under
> Lambda") indicates that it is not possible to prove this as a lemma, but
> does adding this axiom lead to inconsistencies?
This question comes up often, but is actually answered (in the
negative) in the Coq FAQ, http://coq.inria.fr/doc/faq.html, question
31, which contains an interesting list of "safe" axioms and their
relative strengths.
Speaking of extensionality and the FAQ, I find the answer to question
35 rather dubious (although it conforms to the party line):
« Extensionality of functions is an axiom in, say set theory, but from
a programing point of view, extensionality cannot be a priori accepted
since it would identify, say programs such as mergesort and
quicksort. »
Coq's conversion rules already identify some rather different programs
such as the following linear-time and exponential-time algorithms:
Fixpoint two_to_the (n: nat) : Z :=
match n with O => 1 | S m => let r := two_to_the m in r + r end.
Fixpoint two_to_the' (n: nat) : Z :=
match n with O => 1 | S m => two_to_the' m + two_to_the' m end.
So, I don't quite see why functional extensionality "cannot be
accepted from a programming point of view", but the above
identification can...
- Xavier Leroy
- [Coq-Club] Extensional Equality for Function Types, Steve Zdancewic
- Re: [Coq-Club] Extensional Equality for Function Types,
Conor McBride
Benjamin Werner
- Re: [Coq-Club] Extensional Equality for Function Types, Conor McBride
Benjamin Werner
- Re: [Coq-Club] Extensional Equality for Function Types, Haixing Hu
- Re: [Coq-Club] Extensional Equality for Function Types, Xavier Leroy
Jason Hickey
jean-francois . monin
Jason Hickey
roconnor
Conor McBride
- Re: [Coq-Club] Extensional Equality for Function Types, Jason Hickey
- Re: [Coq-Club] Extensional Equality for Function Types, Frederic Blanqui
Conor McBride
roconnor
Jason Hickey
- Re: [Coq-Club] Extensional Equality for Function Types, Benjamin Werner
Jason Hickey
Conor McBride
- <Possible follow-ups>
