- To: coq-club AT pauillac.inria.fr
- Cc: roconnor AT theorem.ca, ctm AT cs.nott.ac.uk
- Subject: Re: [Coq-Club] Extensional Equality for Function Types
- Date: Mon, 14 Feb 2005 14:23:02 -0800
Thanks Conor for a most comprehensive answer!
Conor McBride wrote:
I grew up in a religious warzone where the first thing we learned was:
whatever you say, say nothing.
And I should be more polite in my challenges:) Coq is really very carefully designed.
We should be careful to distinguish extensionality as an axiom, from the
thing which makes 'extensional type theory' extensional: the equality
reflection rule. Equality reflection says that two provably equal things
become definitionally equal.
Gamma |- q : x =_T y (q proves proposition 'x equals y in T')
Gamma |- x === y : T (x judgmentally equal to y in T)
It is such a wonderfully strong principle, but the price is so high! In one broad stroke, equality reflection requires the non-observability of
extensionally equal values in all contexts. One compromise we use is to
assume that equality reflection only holds on types where the elements
have canonical representatives. This includes only unit, bool, int, and
sums and products of those types.
As your examples show, one real cost of extensionality regards the
interpretation of judgments. What do we mean by the following judgment?
f : A -> B, q : P1 |- P2
For the judgment to be well-formed, P1 must be functional with respect
to f, and P2 must be functional with respect to f and q. Clearly, the
finer the equality on (A -> B), the easier this is to show. The
semantics of PRL judgments is complicated for this reason.
(1) there are such liars in the world, such cheats
Q : nat = (nat -> nat) |- (lambda x : nat. x x) (lambda x : nat. x x)
: nat
I see, and with an empty context and intensional function equality, this
can't arise. To spell it out, in extensional type theory, if we assume
void is an empty type, then the following holds for fairly arbitrary
formulas e1 and e2. In fact, termination wouldn't really matter, since
these functions can never be applied.
|- (lambda x : void. e1) = (lambda x : void. e2)
If you look at the equality reflection rule, you'll see that it makes
checking the equality judgment impossible: it requires dreaming up
the proof q which makes the premise hold.
Another good point!
Jason, have you guys cracked it? Have
you got a system where
(a) extensionality holds propositionally
(b) values in the empty context are canonical
(c) the judgmental equality is decidable, hence so is typechecking
(d) symbolic evaluation under false hypotheses terminates
This may seem surprising, but in the PRL theories, only (a) holds. In
PRL, computation is defined on untyped terms and is treated
definitionally. The following fact is true:
Gamma |- 0 : nat
The following fact is identical.
Gamma |- ((lambda x. 0) omega) : nat
where
omega = (lambda x. x x) (lambda x. x x)
So:
(b) values can never be assumed to be canonical
(c) proof terms are usually only weakly normalizing,
equality and typechecking are undecidable in general
(d) symbolic evaluation does not terminate in general
The extreme example uses the intersection type
Top === (isect x : void. void), which contains all terms,
including non-terminating ones, and all elements of
Top are equal.
You might be aghast by this, but the practical consequences are not so bad.
1. Type checking becomes a proof obligation.
Usually (but not always), these proof obligations
are easily proved automatically.
2. Proof checking requires checking the entire derivation.
Its still decidable, but more complicated than a type
checking problem.
In return, the PRL type theory is expressive, with things like extensional function equality, quotient types, very-dependent function types, intersections, etc.
The rule for substitution might help illustrate the functionality issue. In the following rule, one must show that C[x] is functional with respect to type T.
Gamma |- e1 = e2 : T
Gamma, x : T |- C[x] : Type (* functionality *)
Gamma |- C[e2]
Gamma |- C[e1]
The Coq theory gains a lot from nice properties like SN, decidable type checking, canonical values, and more. It would be unfortunate if these properties were compromised by extensional function equality--and probably not worth adding if so.
Jason
Jason Hickey http://www.cs.caltech.edu/~jyh
Caltech Computer Science Tel: 626-395-6568 FAX: 626-792-4257
- Re: [Coq-Club] Extensional Equality for Function Types, (continued)
Conor McBride
Benjamin Werner
- Re: [Coq-Club] Extensional Equality for Function Types, Conor McBride
Benjamin Werner
- Re: [Coq-Club] Extensional Equality for Function Types, Haixing Hu
Xavier Leroy
Jason Hickey
jean-francois . monin
Jason Hickey
roconnor
Conor McBride
- Re: [Coq-Club] Extensional Equality for Function Types, Jason Hickey
- Re: [Coq-Club] Extensional Equality for Function Types, Frederic Blanqui
Conor McBride
roconnor
Jason Hickey
- Re: [Coq-Club] Extensional Equality for Function Types, Benjamin Werner
Jason Hickey
Conor McBride
