coq-club - Re: [Coq-Club] Extensional Equality for Function Types
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Cc: Study group on Mechanized Metatheory for the Masses <provers AT lists.seas.upenn.edu>
  • Subject: Re: [Coq-Club] Extensional Equality for Function Types
  • Date: Sat, 12 Feb 2005 01:05:45 -0800
  • Organization: Caltech
jean-francois.monin AT imag.fr
 wrote:
The relation with time complexity is not very clear here since
mergesort and quicksort are both O(n*log n) "in most practical
cases". They are just completely different algorithms.
Of course. I had assumed that if one cared about the difference between mergesort and quicksort, then one might also care about the difference between mergesort and bubblesort:)
Seriously though, I'm curious why Coq does not admit function extensionality. The PRL (Martin-Lof-style) type theories are carefully intensional with two exceptions--the function type is fully extensional, and the quotient type is partially extensional.
Function and quotient extensionality are wonderful to work with--they tend to enhance reasoning, rather than compromising it as most extensional types would (for instance, an extensional Prop can be very hard to work with).
Certainly, function extensionality abandons any hope of preserving computational complexity. But type theory is not designed so that equality preserves complexity! If you want that, abandon CoIC, and use a Fefferman-style type theory where equality is alpha-equality.
The PRL theories are different from CoIC of course. In PRL, type membership is undecidable (in CoC it is decidable), but in PRL general recursion is fine (CoC only allows primitive recursion). These tradeoffs are behind an obscure trans-Atlantic type-theoretic feud:)
But, let me throw down the guantlet. Why are the Coq folks so backward as to refuse function extensionality? If there are technical reasons, why not be clear about it, and define a standard theory extension for people who care about reasoning, not complexity?
Jason
Jason Hickey                  http://www.cs.caltech.edu/~jyh
Caltech Computer Science      Tel: 626-395-6568 FAX: 626-792-4257
