- From: Benjamin Werner <benjamin.werner AT inria.fr>
- To: Thorsten Altenkirch <txa AT Cs.Nott.AC.UK>
- Cc: Xavier Leroy <Xavier.Leroy AT inria.fr>, Benjamin Pierce <bcpierce AT cis.upenn.edu>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Inductive definitions that go through lists
- Date: Thu, 22 Nov 2007 11:45:38 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:in-reply-to:references:mime-version:content-type:message-id:cc:content-transfer-encoding:subject:date:to:x-mailer:from:sender; b=smoR4qqoUW/NWUNHiuJ50lmmtgXYENyrIFnJOob4PZxtXRhVlY+Qm7K8Dq4NDd+2dtYwCWFJkitmRG29DlxiJtJ/iZKDCluFZBS7ENIZ7qtvYSHsL464Iem3pfrJ/0wACliKjCSiTK0VZcjQ9OlVa1c7Ow1Vilu6SYK0KAdaDh4=
Hi,
Actually, the two presentations are quite similar (and equivalent). The difference
being that I in-lined a possible definition of liftP. Abstracting liftP, as Stéphane did it,
indeed allows to avoid the fix tactic. On the other hand, one will want to specialize
his induction scheme for a particular liftP before using it (say, I would).
About using 'In' for liftP. I thought about it but wanted to avoid dealing with equalities
in the proof of the induction scheme. You can derive a variant with In easily. However
It is not obvious which version I would prefer. Maybye I am influenced by ssreflect so
I now replace constructors by reduction whereever possible :-)
Anyway, the good news is that we are now down to matters of taste :-)
Cheers,
Benjamin
Le 21 nov. 07 à 23:19, Thorsten Altenkirch a écrit :
Hi Xavier,
I wonder what you and Stephane mean by "most general" because it is straightforward to deduce Stephane's induction principle from Benjamin W's (just using induction over lists). I.e. once you assume Stephane's assumptions it is easy to show
forall lt:list ty,liftp P lt -> liftedP lt
using induction over lists and then you use Benjamin's principle to show forall t:ty,P t. Indeed the isomorphism between nested and mutual inductive definition is usually referred to as "Bekic's lemma" and it entails that the corresonding induction principles are equivalent.
From this mutual induction principle, it is rather easy to prove more
specialized principles like the one Benjamin W. showed, with "liftp P"
as the property for "list ty" --- certainly easier than proving them
from scratch.
Or vice versa. Benjamin's principle seems to be the more natural to me, since it just generalizes the present scheme for deriving induction principles to allow nested occurences of inductive types.
Cheers,
Thorsten
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
- Re: [Coq-Club] Inductive definitions that go through lists, (continued)
- Re: [Coq-Club] Inductive definitions that go through lists, Robert Dockins
Benjamin Werner
Thorsten Altenkirch
Stéphane Lescuyer
- Re: [Coq-Club] Inductive definitions that go through lists, Benjamin Pierce
Stéphane Lescuyer
Xavier Leroy
Xavier Leroy
- Re: [Coq-Club] Inductive definitions that go through lists, Francesco Zappa Nardelli
- Re: [Coq-Club] Inductive definitions that go through lists, Stefan Berghofer
Thorsten Altenkirch
- Re: [Coq-Club] Inductive definitions that go through lists, Benjamin Werner
- Re: [Coq-Club] Inductive definitions that go through lists, frederic . blanqui
Xavier Leroy
Thorsten Altenkirch
