coq-club - Re: [Coq-Club] Inductive definitions that go through lists
chronological Thread
  • To: Benjamin Werner <Benjamin.Werner AT inria.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Inductive definitions that go through lists
  • Date: Sat, 24 Nov 2007 10:39:46 -0500
* The definitions of the type theory which make this correct are described in the ref man.
The fix tactic is in the tutorial on recursive types (Gimenez and Casteran).
BTW, all I can find in the tutorial is one example with a short paragraph of explanation (on p. 47) -- not really enough to get the full picture of what "fix" is doing. Is there a longer discussion anyplace, or should I just try to read the source?
Meta-question: This discussion has been extremely informative and it would be a shame for it to get lost in the mailing list archives. I would be very happy to cut and paste all of the relevant emails into a Wiki page or some such if there were an easy and obvious way to do it. Is there? (It's not clear whether the cocorico site is still alive -- all the recent edits seem to be spam.)
    - Benjamin
Maybye there are smoother versions of the above. Also, my understanding is
that if this work is not done generically by Coq, it is a.o. because it is not so
trivial to state the good induction principle.
Hope this helps,
Benjamin
Le 21 nov. 07 à 04:20, Benjamin Pierce a écrit :
This week, I wanted to show my programming languages class how to extend the simply typed lambda-calculus with records. So I wrote the obvious thing:
   Inductive ty : Set :=
     | ty_base     : nat -> ty
     | ty_arrow    : ty -> ty -> ty
     | ty_rcd      : (alist ty) -> ty.
This seemed happy for a while, until I discovered that the induction principle Coq had generated
   ty_ind
     : forall P : ty -> Prop,
       (forall n : nat, P (ty_base n)) ->
(forall t : ty, P t -> forall t0 : ty, P t0 -> P (ty_arrow t t0)) ->
       (forall a : alist ty, P (ty_rcd a)) -> forall t : ty, P t
was completely useless! (The last case gives no IH for reasoning about records.)
I asked around a little at Penn and was told that this was a common issue and the usual way around it was to "lift" the nil and cons constructors of lists into my term syntax, like this:
    | ty_rcd_nil  : ty
    | ty_rcd_cons : nat -> ty -> ty -> ty.
This made me a little less happy because it slightly changes the language I'm defining, but I pushed ahead and succeeded in proving all the things I wanted to about the system.
Next, I'd like to show the class the "dual" extension: variants (i.e., disjoint sums with any number of labeled summands). But this time I'm even less happy. I'd like to write
  Inductive tm : Set :=
    | tm_var : nat -> tm
    | tm_app : tm -> tm -> tm
    | tm_abs : nat -> ty -> tm -> tm
    | tm_inj : nat -> tm -> tm
    | tm_case : tm -> list (nat * tm) -> tm.
where the last constructor represents an n-ary case construct whose concrete syntax might look like this:
     case t0 of <l1=x1> => t1
              | <ln=xn> => tn
This won't work for the same reason as before. And, while I can roughly see how to generalize the "case" constructor into a "nil" and a "cons" part as I did for records, this is really getting a bit awkward.
Is there a more direct way to do such things?
Thanks!
    - Benjamin
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
