coq-club - Re: [Coq-Club] FSet Extensionality Not defined
chronological Thread
  • From: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
  • To: "M. Scott Doerrie" <mdoerri AT cs.jhu.edu>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] FSet Extensionality Not defined
  • Date: Wed, 18 Mar 2009 19:45:59 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=vvdhalW1D/vwQBGIGsv4HJ3ilpBtTjrHZBdhYuzwNVsdQmnCEKL0cE1EkHc8JBzRMB X/AE1IbYxXCQlK90OzLX3nD1i4F6F6tkQrLBZc70JEmALQ8cEb1URhkjdjgi1USfgvgM 7ErDNFFVGhBkiN83CXl6istP0vlNUkhLl+73w=
Hi, even with an UsualOrderedType, extensionality is not true in
general for FSets since it depends on the actual representation : two
different AVLs can represent the same set for instance. Even with
sorted lists, where you might expect the property to be true, it would
require the proof-irrelevance of the proof that the list is sorted.
S.L.
On Wed, Mar 18, 2009 at 7:20 PM, M. Scott Doerrie
 wrote:
> I would really like to have an axiom-free method of constructing Ensembles
> from FSets.  However, I can't find any definition for
> Extensionality_Ensembles in FSetToFiniteSet in any version of the Coq
> standard library.  I believe this axiom would be derivable if creating FSets
> from UsualOrderedTypes, yet I can not locate it.  Did I miss something?  Is
> this not possible?
> Scott Doerrie
> Bug reports: http://logical.saclay.inria.fr/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
>         http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
