- To: "M. Scott Doerrie" <mdoerri AT cs.jhu.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] FSet Extensionality Not defined
- Date: Wed, 18 Mar 2009 16:01:47 -0400
M. Scott Doerrie wrote:
I suppose I have assumed that since everything is complete, decidable, deterministic, and finite, that the result of union_sort and add_sort would be identical structures when union and add produced identical structures. Why can I talk about having identical resulting structures over union and add and not union_sort and add_sort?
The latter return proofs. Coq's type system _intentionally_ blocks some "obvious" computational equivalences over proofs, so that extraction to OCaml is sound. Extraction erases proofs, so it's important that some kinds of computations over proofs are impossible, since the proofs won't be around "at runtime" to compute with.
Also, even ignoring this (which I'm not sure is fair to give as the culprit for your problem), imagine that we encode proofs in [Set] instead. You _can_ talk about having identical structures here, but you don't automatically get that every possible comparison type has exactly one member. This depends on the details of individual notions of comparison.
- [Coq-Club] FSet Extensionality Not defined, M. Scott Doerrie
- Re: [Coq-Club] FSet Extensionality Not defined, Taral
Stéphane Lescuyer
M. Scott Doerrie
Adam Chlipala
- Re: [Coq-Club] FSet Extensionality Not defined, Bruno Barras
Stéphane Lescuyer
M. Scott Doerrie
Stéphane Lescuyer
- Re: [Coq-Club] FSet Extensionality Not defined, M. Scott Doerrie
- Re: [Coq-Club] FSet Extensionality Not defined, Adam Chlipala
Stéphane Lescuyer
M. Scott Doerrie
- RE: [Coq-Club] FSet Extensionality Not defined, Georges Gonthier
Adam Chlipala
M. Scott Doerrie
- Re: [Coq-Club] FSet Extensionality Not defined, Pierre Letouzey
