- To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] FSet Extensionality Not defined
- Date: Wed, 18 Mar 2009 15:04:50 -0400
You are correct that I've been assuming FSetLists as my structure. I had not considered the AVL structure, for which this wouldn't hold.
I do not understand where proof-irrelevance would enter for FSetLists. I had thought that with identical representations, the proofs of sorting would also be identical. What did I miss here?
Scott Doerrie
Stéphane Lescuyer wrote:
Hi, even with an UsualOrderedType, extensionality is not true in
general for FSets since it depends on the actual representation : two
different AVLs can represent the same set for instance. Even with
sorted lists, where you might expect the property to be true, it would
require the proof-irrelevance of the proof that the list is sorted.
S.L.
On Wed, Mar 18, 2009 at 7:20 PM, M. Scott Doerrie
<mdoerri AT cs.jhu.edu>
wrote:
I would really like to have an axiom-free method of constructing Ensembles
from FSets. However, I can't find any definition for
Extensionality_Ensembles in FSetToFiniteSet in any version of the Coq
standard library. I believe this axiom would be derivable if creating FSets
from UsualOrderedTypes, yet I can not locate it. Did I miss something? Is
this not possible?
Scott Doerrie
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] FSet Extensionality Not defined, M. Scott Doerrie
- Re: [Coq-Club] FSet Extensionality Not defined, Taral
Stéphane Lescuyer
- Re: [Coq-Club] FSet Extensionality Not defined, M. Scott Doerrie
Adam Chlipala
- Re: [Coq-Club] FSet Extensionality Not defined, Bruno Barras
Stéphane Lescuyer
M. Scott Doerrie
Stéphane Lescuyer
- Re: [Coq-Club] FSet Extensionality Not defined, Adam Chlipala
Stéphane Lescuyer
M. Scott Doerrie
- RE: [Coq-Club] FSet Extensionality Not defined, Georges Gonthier
Adam Chlipala
- Re: [Coq-Club] FSet Extensionality Not defined, Pierre Letouzey
