- To: "M. Scott Doerrie" <mdoerri AT cs.jhu.edu>
- Cc: St�phane Lescuyer <stephane.lescuyer AT inria.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] FSet Extensionality Not defined
- Date: Wed, 18 Mar 2009 15:11:18 -0400
M. Scott Doerrie wrote:
You are correct that I've been assuming FSetLists as my structure. I had not considered the AVL structure, for which this wouldn't hold.
I do not understand where proof-irrelevance would enter for FSetLists. I had thought that with identical representations, the proofs of sorting would also be identical. What did I miss here?
A proof of sortedness can involve arbitrary mathematical machinery. What is it that makes you think that any two such proofs can be shown equal in Coq? This would require showing that, modulo the definitional equality, the proofs have the same syntax. There can be many proofs of the same proposition that use very different proof strategies and so have very different syntax.
- [Coq-Club] FSet Extensionality Not defined, M. Scott Doerrie
- Re: [Coq-Club] FSet Extensionality Not defined, Taral
Stéphane Lescuyer
M. Scott Doerrie
- Re: [Coq-Club] FSet Extensionality Not defined, Adam Chlipala
- Re: [Coq-Club] FSet Extensionality Not defined, Bruno Barras
Stéphane Lescuyer
M. Scott Doerrie
Stéphane Lescuyer
- Re: [Coq-Club] FSet Extensionality Not defined, M. Scott Doerrie
Stéphane Lescuyer
M. Scott Doerrie
- RE: [Coq-Club] FSet Extensionality Not defined, Georges Gonthier
M. Scott Doerrie
- Re: [Coq-Club] FSet Extensionality Not defined, Pierre Letouzey
