coq-club - Re: [Coq-Club] FSet Extensionality Not defined
chronological Thread
  • To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] FSet Extensionality Not defined
  • Date: Wed, 18 Mar 2009 15:53:52 -0400
I suppose I have assumed that since everything is complete, decidable, deterministic, and finite, that the result of union_sort and add_sort would be identical structures when union and add produced identical structures. Why can I talk about having identical resulting structures over union and add and not union_sort and add_sort?
Scott Doerrie
Stéphane Lescuyer wrote:
Indeed, proofs of sorting are not identical for identical lists. They
depend on the way you built the list : consider for instance the set S
= {x, y} where x < y. If you build it by merging {x} and {y}, the
proof of sortedness will be something like "union_sort _ _ (proof that
{x} is sorted) (proof that {y} is sorted)" where union_sort is a lemma
stating that merging two sorted lists yiels a sorted list.
If, on the contrary, you build S by adding x to {y}, the proof of
well-sortedness will be something like "add_sort _ _ (proof that {y}
is sorted)", and there is no relation a priori between add_sort and
union_sort.
S.L.
2009/3/18 M. Scott Doerrie
<mdoerri AT cs.jhu.edu>:
You are correct that I've been assuming FSetLists as my structure.  I had
not considered the AVL structure, for which this wouldn't hold.
I do not understand where proof-irrelevance would enter for FSetLists.  I
had thought that with identical representations, the proofs of sorting would
also be identical.  What did I miss here?
Scott Doerrie
Hi, even with an UsualOrderedType, extensionality is not true in
general for FSets since it depends on the actual representation : two
different AVLs can represent the same set for instance. Even with
sorted lists, where you might expect the property to be true, it would
require the proof-irrelevance of the proof that the list is sorted.
S.L.
On Wed, Mar 18, 2009 at 7:20 PM, M. Scott Doerrie
wrote:
I would really like to have an axiom-free method of constructing
Ensembles
from FSets.  However, I can't find any definition for
Extensionality_Ensembles in FSetToFiniteSet in any version of the Coq
standard library.  I believe this axiom would be derivable if creating
FSets
from UsualOrderedTypes, yet I can not locate it.  Did I miss something?
 Is
this not possible?
Scott Doerrie
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
       http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
