- To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] FSet Extensionality Not defined
- Date: Wed, 18 Mar 2009 16:28:55 -0400
Understood. Thank you.
The high-level implications of this are that I can not use define relations (ala Relations_N modules) over FSetLists to form a partial order and reuse those theorems to build up my proof. I can not define a complete definition of Antisymmetry.
Scott Doerrie
Stéphane Lescuyer wrote:
Well, it's not a theoretical limit, just the way it's done in the
library. As Georges explained, sortedness is decidable as soon as
comparison is, but the proofs are not done along those lines in FSet,
and the lemmas add_sort/union_sort/remove_sort/.... are opaque so even
if they were creating the exact same object under the hood (which they
arent), the results still wouldn't be equal because Coq couldnt' check
that they are convertible to one another.
2009/3/18 M. Scott Doerrie
<mdoerri AT cs.jhu.edu>:
I suppose I have assumed that since everything is complete, decidable,
deterministic, and finite, that the result of union_sort and add_sort would
be identical structures when union and add produced identical structures.
Why can I talk about having identical resulting structures over union and
add and not union_sort and add_sort?
Scott Doerrie
Indeed, proofs of sorting are not identical for identical lists. They
depend on the way you built the list : consider for instance the set S
= {x, y} where x < y. If you build it by merging {x} and {y}, the
proof of sortedness will be something like "union_sort _ _ (proof that
{x} is sorted) (proof that {y} is sorted)" where union_sort is a lemma
stating that merging two sorted lists yiels a sorted list.
If, on the contrary, you build S by adding x to {y}, the proof of
well-sortedness will be something like "add_sort _ _ (proof that {y}
is sorted)", and there is no relation a priori between add_sort and
union_sort.
S.L.
You are correct that I've been assuming FSetLists as my structure. I had
not considered the AVL structure, for which this wouldn't hold.
I do not understand where proof-irrelevance would enter for FSetLists. I
had thought that with identical representations, the proofs of sorting
would
also be identical. What did I miss here?
Scott Doerrie
Hi, even with an UsualOrderedType, extensionality is not true in
general for FSets since it depends on the actual representation : two
different AVLs can represent the same set for instance. Even with
sorted lists, where you might expect the property to be true, it would
require the proof-irrelevance of the proof that the list is sorted.
S.L.
On Wed, Mar 18, 2009 at 7:20 PM, M. Scott Doerrie
wrote:
I would really like to have an axiom-free method of constructing
Ensembles
from FSets. However, I can't find any definition for
Extensionality_Ensembles in FSetToFiniteSet in any version of the Coq
standard library. I believe this axiom would be derivable if creating
FSets
from UsualOrderedTypes, yet I can not locate it. Did I miss something?
Is
this not possible?
Scott Doerrie
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] FSet Extensionality Not defined, M. Scott Doerrie
- Re: [Coq-Club] FSet Extensionality Not defined, Taral
Stéphane Lescuyer
M. Scott Doerrie
Adam Chlipala
- Re: [Coq-Club] FSet Extensionality Not defined, Bruno Barras
Stéphane Lescuyer
M. Scott Doerrie
Stéphane Lescuyer
- Re: [Coq-Club] FSet Extensionality Not defined, M. Scott Doerrie
- Re: [Coq-Club] FSet Extensionality Not defined, Adam Chlipala
Stéphane Lescuyer
M. Scott Doerrie
- RE: [Coq-Club] FSet Extensionality Not defined, Georges Gonthier
Adam Chlipala
M. Scott Doerrie
- Re: [Coq-Club] FSet Extensionality Not defined, Pierre Letouzey
