- To: taralx AT gmail.com
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] case & inversion, Set & Prop
- Date: Fri, 07 Aug 2009 22:29:55 +0900 (JST)
Thanks for the explanation (to Adam as well).
I hit this problem in an attempt to use Prop as impredicative Set.
Having learned that the use of Set-valued nat confused me,
I wonder if I can avoid them.
Namely, is there a Prop-valued equivalent to nat and Z?
Best,
Keiko
- [Coq-Club] case & inversion, Set & Prop, Keiko Nakata
- Re: [Coq-Club] case & inversion, Set & Prop,
Adam Chlipala
Keiko Nakata
- Re: [Coq-Club] case & inversion, Set & Prop, Adam Chlipala
Keiko Nakata
Taral
- Re: [Coq-Club] case & inversion, Set & Prop, Keiko Nakata
Adam Chlipala
Keiko Nakata
Adam Chlipala
Keiko Nakata
Keiko Nakata
Adam Chlipala
Keiko Nakata
Adam Chlipala
Adam Chlipala
