- To: Keiko Nakata <keiko AT kurims.kyoto-u.ac.jp>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] case & inversion, Set & Prop
- Date: Thu, 06 Aug 2009 08:53:39 -0400
Keiko Nakata wrote:
I have been confused by different behaviour of case and inversion tactics,
when I moved from Set to Prop. Will someone please explain?
In the following code, the last "inversion h1" is not helpful at all.
Inductive list: Prop :=
| nil: nat -> list.
Inductive list_eq: list -> list -> Prop :=
| nil_eq: forall n, list_eq (nil n) (nil n).
Lemma inversion_list: forall l0 l1, list_eq l0 l1 -> list_eq l1 l0.
Proof.
intro l0. case l0. intro n0. intro l1. case l1. intro n1. intro h1. inversion h1. (* This changes nothing, so I've got stuck.)
There's a generic way of answering this kind of question. For this case, you can run the following with [list] in [Set]:
Lemma invert : forall n1 n2, list_eq (nil n1) (nil n2) -> n1 = n2.
inversion 1; reflexivity.
Qed.
Print invert.
Now you know how [invert] wants to prove this goal. You can try to type-check this exact proof term after moving [list] to [Prop]. I get this error message:
Incorrect elimination of "e" in the inductive type "list":
the return type has sort "Set" while it should be "Prop".
Elimination of an inductive object of sort Prop
is not allowed on a predicate in sort Set
because proofs can be eliminated only to build proofs.
Inspecting the proof term, we see that this error message is essentially complaining about the inability to write a function that extracts a [nat] from a [list], by picking out the argument to [nil].
- [Coq-Club] case & inversion, Set & Prop, Keiko Nakata
- Re: [Coq-Club] case & inversion, Set & Prop, Adam Chlipala
Keiko Nakata
Keiko Nakata
Taral
Keiko Nakata
Adam Chlipala
Keiko Nakata
Adam Chlipala
Keiko Nakata
Keiko Nakata
Adam Chlipala
- Re: [Coq-Club] case & inversion, Set & Prop, Keiko Nakata
Keiko Nakata
Adam Chlipala
Keiko Nakata
