coq-club - Re: [Coq-Club] case & inversion, Set & Prop
chronological Thread
  • To: Keiko Nakata <keiko AT kurims.kyoto-u.ac.jp>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] case & inversion, Set & Prop
  • Date: Thu, 06 Aug 2009 10:37:04 -0400
Keiko Nakata wrote:
Thank you for the prompt and instructive answer. But my understanding is still partial :(
The following code works fine:
Inductive list: Prop :=
| nil: nat -> list.
Inductive list_eq: list -> list -> Prop :=
| nil_eq: forall n, list_eq (nil n) (nil n).
Lemma invert_again: forall l0 l1, list_eq l0 l1 -> l1 = l0.
Proof.
inversion 1; reflexivity.
Qed.
I do not know where is the crucial difference in proof terms of your "invert"
and my "invert_again".
Well, the error message from my last posting indicated a problem with writing function to extract the argument to [nil]. Your [invert_again] doesn't need to look inside lists in this way, because it only talks about lists, not numbers.
It's hard to give a precise and intuitive answer. The best I can suggest is printing the proof term for [invert_again], too, and comparing with the proof term I [Print]ed in my last message. You should at least see the presence of a [nat]-grabbing function in the old version and the absence of such a function in your new version.
