- From: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- To: Thomas Braibant <thomas.braibant AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] A not so FSet specific question about destruction
- Date: Mon, 19 Oct 2009 16:23:20 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=fDTBS1DndTj21LQBe7735peVZKQxV5UAMPFXXcJ0XnrHY9Uy8BPmzSWQFZ5xJZX9CO 0MpkJ6MVIzHSGaY9aZ//+sEB4hSIl1V3iYrjQ7r9utVaHOPjeKeUp7FYvon2DTFmraMu HFtgbD790t8L2Dy24ulWU0eeWwWDKzVVrViU8=
Hi Thomas,
> I was then told that I could use inductives, to do the same job.
> Inductive mem_spec_ind : elt -> t -> bool -> Type :=
> | mem_spec_1 : forall x s, In x s -> mem_spec_ind x s true
> | mem_spec_2 : forall x s, ~In x s -> mem_spec_ind x s false.
> Lemma mem_eq : forall x s, mem_spec_ind x s (mem x s). Admitted.
> Unfortunately, "destruct"-ing mem_eq in a Goal can lead to the
> forgetting of useful informations. I have to remember some pieces of
> information by hand, while everything is smoother using the
> rewrite-destruct scheme.
You should just be careful writing the inductive spec : uniform
parameters are not the same thing as variables introduced in the
constructors. In that case, you should have written :
Inductive mem_spec_ind x s : bool -> Type :=
| mem_spec_1 : In x s -> mem_spec_ind x s true
| mem_spec_2 : ~In x s -> mem_spec_ind x s false.
and then destructing (mem_eq t1 t2) does not 'erase' t1 and t2, and
everything goes fine :
Goal forall x y z , (if mem z (add x (add y (singleton z))) then 1 else 2)=
1.
intros.
destruct (mem_eq z (add x (add y (singleton z)))).
reflexivity.
setdec.
Qed.
Even with the 'wrong' definition you can also use inversion(_clear)
instead of destruct and you won't lose any information, but
unfortunately you'd have to explictely introduce the hypothesis to be
inverted. I'd like it a lot, actually, if the inversion tactic were to
work on arbitrary constructions instead of just hypotheses
identifiers.
On a more specific note, in your particular goal here, I'd rather use
existing lemmas and proceed without case split at all : rewrite twice
using EqProps.add_mem_3 and then EqProps.singleton_mem_1. If I can
give a direct proof, I tend to do it.
Cheers,
Stéphane
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
- [Coq-Club] A not so FSet specific question about destruction, Thomas Braibant
- Re: [Coq-Club] A not so FSet specific question about destruction, Stéphane Lescuyer
Guillaume Melquiond
Guillaume Melquiond
- Re: [Coq-Club] A not so FSet specific question about destruction, Matthieu Sozeau
- [Coq-Club] an inductive types question (2),
Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question (2), Adam Chlipala
Cody Roux
Vladimir Voevodsky
Cody Roux
- Re: [Coq-Club] an inductive types question (2), Vladimir Voevodsky
Cody Roux
Vladimir Voevodsky
