coq-club - Re: [Coq-Club] an inductive types question (2)
chronological Thread
  • To: Cody Roux <Cody.Roux AT loria.fr>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] an inductive types question (2)
  • Date: Tue, 20 Oct 2009 12:43:18 -0400
(cont.) Is it also true that any closed term of type nat reduces to a term of the form S ... S O ?
V.
On Oct 20, 2009, at 6:38 AM, Cody Roux wrote:
On Tue, 2009-10-20 at 12:24 -0400, Vladimir Voevodsky wrote:
Given an inductive type such as
Inductive two_el := el_1 | el_2 .
are there closed terms of type two_el which do not reduce to either
el_1 or el_2 ?
No. This can be deduced from the strong normalisation property of the
underlying calculus of Coq (CIC+Predicative Set+Universes), combined
with the Inversion Property: It is easy to show by case analysis that
any term in normal form and in the empty context of type two_el must be
one of the constructors of this type. This can be compared with the
disjunction property which states:
If t is a term of type A\/B in the empty context then t reduces to
inl t1   or to    inr t2
Which happens to be quite a desirable property in constructive
mathematics.
Cheers
Cody
