- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] A not so FSet specific question about destruction
- Date: Mon, 19 Oct 2009 16:50:00 +0200
Stéphane Lescuyer a écrit :
You should just be careful writing the inductive spec : uniform
parameters are not the same thing as variables introduced in the
constructors. In that case, you should have written :
Inductive mem_spec_ind x s : bool -> Type :=
| mem_spec_1 : In x s -> mem_spec_ind x s true
| mem_spec_2 : ~In x s -> mem_spec_ind x s false.
Lemma mem_eq : forall x s, mem_spec_ind x s (mem x s). Admitted.
and then destructing (mem_eq t1 t2) does not 'erase' t1 and t2, and
everything goes fine :
Goal forall x y z , (if mem z (add x (add y (singleton z))) then 1 else 2)=
1.
intros.
destruct (mem_eq z (add x (add y (singleton z)))).
Stephane's solution is correct. I would just like to point that there is a better tactic than "destruct" for this kind of inductives:
case mem_eq. (* No arguments! Coq infers them when using "case". *)
Best regards,
Guillaume
- [Coq-Club] A not so FSet specific question about destruction, Thomas Braibant
- Re: [Coq-Club] A not so FSet specific question about destruction,
Stéphane Lescuyer
- Re: [Coq-Club] A not so FSet specific question about destruction, Guillaume Melquiond
- Re: [Coq-Club] A not so FSet specific question about destruction, Stéphane Lescuyer
- Re: [Coq-Club] A not so FSet specific question about destruction, Matthieu Sozeau
- [Coq-Club] an inductive types question (2),
Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question (2), Adam Chlipala
Cody Roux
Vladimir Voevodsky
Cody Roux
- Re: [Coq-Club] an inductive types question (2), Vladimir Voevodsky
Cody Roux
Vladimir Voevodsky
Stéphane Lescuyer
