coq-club - Re: [Coq-Club] an inductive types question (2)
chronological Thread
  • To: Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] an inductive types question (2)
  • Date: Tue, 20 Oct 2009 12:32:16 -0400
Vladimir Voevodsky wrote:
Given an inductive type such as
Inductive two_el := el_1 | el_2 .
are there closed terms of type two_el which do not reduce to either el_1 or el_2 ?
That depends on the axioms that you assert. With no axioms, I believe the CIC consistency theorem guarantees the property you describe (modulo differences between the real Coq implementation and the theory).
The axiom from the [Eqdep] module is a good example of a term that can block complete reduction, but is very useful. There is also the less interesting case of trying to reduce terms that contain subterms marked as opaque with [Qed] or similar.
