- To: Cody Roux <Cody.Roux AT loria.fr>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] an inductive types question (2)
- Date: Tue, 20 Oct 2009 13:04:18 -0400
(cont.) Does it imply that in the empty context it is impossible to define a function (nat -> nat) -> nat which maps f to its minimal value?
V.
On Oct 20, 2009, at 6:56 AM, Cody Roux wrote:
On Tue, 2009-10-20 at 12:43 -0400, Vladimir Voevodsky wrote:
(cont.) Is it also true that any closed term of type nat reduces to aAlso true, if as Adam has said, you work in a system without (non
term of the form S ... S O ?
V.
computational) axioms. This can be generalized to all inductive types,
though one must notice that in the presence of dependent types, some
instances of the inductive types may be empty e.g.
Inductive ZeroEmpty: nat->Type:=
|Notzero: forall n, ZeroEmpty (S n)
In this case (ZeroEmpty 0) is uninhabited. Nevertheless, every term of
type (ZeroEmpty 0) in the empty context (in this case there are no such
terms) does reduce to (Notzero t).
Cody
On Oct 20, 2009, at 6:38 AM, Cody Roux wrote:
On Tue, 2009-10-20 at 12:24 -0400, Vladimir Voevodsky wrote:
Given an inductive type such as
Inductive two_el := el_1 | el_2 .
are there closed terms of type two_el which do not reduce to either
el_1 or el_2 ?
No. This can be deduced from the strong normalisation property of the
underlying calculus of Coq (CIC+Predicative Set+Universes), combined
with the Inversion Property: It is easy to show by case analysis that
any term in normal form and in the empty context of type two_el must
be
one of the constructors of this type. This can be compared with the
disjunction property which states:
If t is a term of type A\/B in the empty context then t reduces to
inl t1 or to inr t2
Which happens to be quite a desirable property in constructive
mathematics.
Cheers
Cody
- [Coq-Club] A not so FSet specific question about destruction, Thomas Braibant
- Re: [Coq-Club] A not so FSet specific question about destruction,
Stéphane Lescuyer
Guillaume Melquiond
- Re: [Coq-Club] A not so FSet specific question about destruction, Stéphane Lescuyer
Guillaume Melquiond
- Re: [Coq-Club] A not so FSet specific question about destruction, Matthieu Sozeau
- [Coq-Club] an inductive types question (2),
Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question (2), Adam Chlipala
Cody Roux
Vladimir Voevodsky
Cody Roux
- Re: [Coq-Club] an inductive types question (2), Vladimir Voevodsky
Cody Roux
Vladimir Voevodsky
Stéphane Lescuyer
