coq-club - Re: [Coq-Club] local definition in proof mode
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] local definition in proof mode
  • Date: Wed, 7 Apr 2010 11:27:12 -0400
Hi everyone,
  I think the best you can do in the current state is to manipulate
an existential variable for the object explicitely using an encoding
like:
Inductive singleton A : A -> Type := single (x : A) : singleton A x.
Implicit Arguments single [[A]].
Ltac assert_trans x T :=
  evar (x:T); let H := fresh in assert (H:singleton T x); [unfold x; clear
x|clear H].
Lemma singleton_apply {A B} (f : A -> B) (x : A) : singleton A x -> singleton
B (f x).
Proof. intros. destruct X. constructor; auto. Defined.
Goal forall x : nat, True.
intros.
assert_trans foo bool.
(* now in a [singleton bool ?n] goal where we can refine ?n].
apply (singleton_apply negb).
apply (single true).
(* foo := negb true is in the context *)
exact I.
Qed.
It's a hack and doesn't support directly using a tactic to build the term,
but at least
you get the transparency you need.
My 2 cents,
-- Matthieu
Le 7 avr. 2010 à 11:03, Pierre Courtieu a écrit :
> Yes that's right. You can only see its definition but you cannot make
> it transparent.
> P.
> Le 7 avril 2010 15:51, Pierre-Marie Pédrot
> <pierremarie.pedrot AT ens-lyon.fr>
>  a écrit :
>> Technically, it does not work as the term produced through abstract is
>> opaque, so we end up with the very same problem as assert.
>> PMP
