- To: "Jean-Francois Monin" <jean-francois.monin AT imag.fr>, Stéphane Lescuyer <stephane.lescuyer AT inria.fr>
- Cc: andré hirschowitz <ah AT unice.fr>, "Martijn Vermaat" <martijn AT vermaat.name>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] local definition in proof mode
- Date: Tue, 06 Apr 2010 15:08:46 +0200
- Organization: ProVal
I checked it for my previous example, and it works
(but I had no hypothesis, so I am not sure it really works)
Goal exists b: bool, b = true.
Lemma b: bool.
exact true.
Defined.
exists b.
split.
Qed.
Which (if I am correct), means that Jean-François Monin example scheme would be:
Goal forall x : X, exists y: Y, complicated_property x y.
intros x.
Lemma y: Y.
apply many_functions_in_order_to_build_y_from_x.
Defined.
exists y.
(* Here you may want to use "unfold y." *)
apply many_lemmas_for_proving_complicated_property_x_y.
Qed.
and should work.
This solution is not as convenient as having a dedicated tactic, but:
* the number of characters you have to type with this method minus the numbers you should have with a tactic is below 20,
which is largely acceptable
* the Lemma...Defined makes the proof more readable IMO.
Flaws remain:
* we have a new defined term outside of our proof, which name is "y" and type is:
forall (H0: ...) (H1: ...) ..., Y.
And we should want to erase this term.
* This technique cannot be used inside Ltac.
A trick to solve the first flaw would have been to open a section before "Goal" then use "Let" instead of "Lemma"
and close our section, but this doesn't seem to work (the Let is unusable once defined in our goal).
Le Tue, 06 Apr 2010 14:07:45 +0200, Jean-Francois Monin <jean-francois.monin AT imag.fr> a écrit:
As far as i understand, the very value of H may be useful
and defining it in one step may be hard.
Example:
intros x. pose (y: Y).
exists y. apply many_lemmas_for_proving_complicated_property_x_y.
Qed.
Here neither cut nor assert is the answer.
JF
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
- [Coq-Club] local definition in proof mode, andré hirschowitz
- Re: [Coq-Club] local definition in proof mode,
Martijn Vermaat
andré hirschowitz
Stéphane Lescuyer
Guillaume Allais
- Re: [Coq-Club] local definition in proof mode, Pierre-Marie Pédrot
Jean-Francois Monin
- Re: [Coq-Club] local definition in proof mode, AUGER
AUGER
andré hirschowitz
- Re: [Coq-Club] local definition in proof mode, Jean-Francois Monin
AUGER
- Re: [Coq-Club] local definition in proof mode, Pierre Courtieu
- Re: [Coq-Club] local definition in proof mode, Matthieu Sozeau
andré hirschowitz
Guillaume Allais
Stéphane Lescuyer
andré hirschowitz
Martijn Vermaat
