- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] local definition in proof mode
- Date: Tue, 6 Apr 2010 15:07:32 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:content-type; b=eb1Nkee3EhOzv782+5NPC++PfDFLOiviZpWi4FrMlWmwBN3MnfVxhm9FBJO+LjrSjw atTVPuAltSyUhQOpOKqN8RbusUWuHzwj+Ye+CYoKLAUmLAjb6f4EzBQXRjdqpR+ug5Tj TVsQ0TbyfPikNCuh1k7mtF7SVq4VuqVeorVcU=
In fact I doubt that assert is what andre wishes, as I think andre wanted to say,
"assert (H: P)." produces an opaque term, and sometimes (it happened to me), we
should want a transparent term with usable definition.
Exactly. I just want to give a name to an awful term which I am unable to write although I am able to produce it in proof mode.
That makes me think of a maybe real solution, but I am not sure it works:
instead of a "pose (H := _ : P).", you should try a "Lemma H: P."
No, this does not work because the local environment is not taken into account by this command (if my experiment is correct). Neither does Definition for the same reason.
Thanks to all.
ah
- [Coq-Club] local definition in proof mode, andré hirschowitz
- Re: [Coq-Club] local definition in proof mode,
Martijn Vermaat
andré hirschowitz
Stéphane Lescuyer
Guillaume Allais
- Re: [Coq-Club] local definition in proof mode, Pierre-Marie Pédrot
- Re: [Coq-Club] local definition in proof mode, Jean-Francois Monin
AUGER
- Re: [Coq-Club] local definition in proof mode, andré hirschowitz
AUGER
- Re: [Coq-Club] local definition in proof mode, AUGER
- Re: [Coq-Club] local definition in proof mode, Pierre Courtieu
- Re: [Coq-Club] local definition in proof mode, Matthieu Sozeau
Guillaume Allais
Stéphane Lescuyer
andré hirschowitz
Martijn Vermaat
