- From: Pierre-Marie P�drot <pierremarie.pedrot AT ens-lyon.fr>
- To: Pierre Courtieu <Pierre.Courtieu AT cnam.fr>
- Cc: AUGER <Cedric.Auger AT lri.fr>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] local definition in proof mode
- Date: Wed, 07 Apr 2010 15:51:59 +0200
Pierre Courtieu wrote:
> Until this is implemented, let me suggest a very ugly combination of
> assert + abstract. The ugly part is that the definition name generated
> by abstract is automatically chosen by coq (it seems deterministic
> however) and that you have to look at the environment to know it. The
> other ugly part is that you have to put the abstract on the hole set
> of tactics used to prove the sub-lemma, which forces you to put
> semi-colons everywhere.
Technically, it does not work as the term produced through abstract is
opaque, so we end up with the very same problem as assert.
PMP
signature.asc
Description: OpenPGP digital signature
- Re: [Coq-Club] local definition in proof mode, (continued)
- Re: [Coq-Club] local definition in proof mode, Pierre-Marie Pédrot
- Re: [Coq-Club] local definition in proof mode, Jean-Francois Monin
AUGER
andré hirschowitz
AUGER
- Re: [Coq-Club] local definition in proof mode, AUGER
- Re: [Coq-Club] local definition in proof mode, Pierre Courtieu
- Re: [Coq-Club] local definition in proof mode, Matthieu Sozeau
andré hirschowitz
