coq-club - Re: [Coq-Club] local definition in proof mode
chronological Thread
  • To: andré hirschowitz <ah AT unice.fr>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] local definition in proof mode
  • Date: Tue, 06 Apr 2010 15:18:19 +0200
  • Organization: ProVal
Le Tue, 06 Apr 2010 15:07:32 +0200, andré hirschowitz <ah AT unice.fr> a écrit:
In fact I doubt that assert is what andre wishes, as I think andre wanted to
say,
 "assert (H: P)." produces an opaque term, and sometimes (it happened to
me), we
 should want a transparent term with usable definition.
Exactly. I just want to give a name to an awful term which I am unable to
write although I am able to produce it in proof mode.
That makes me think of a maybe real solution, but I am not sure it works:
instead of a "pose (H := _ : P).", you should try a "Lemma H: P."
No, this does not work because the local environment is not taken into
account by this command (if my experiment is correct). Neither does
Definition for the same reason.
:( you are right, sorry for having spammed this list with this (wrong) solution...
I think this feature should be "consistant with Coq spirit",
but it is not implemented so.
It seems I will continue to make those awful Defined Lemma before starting a proof...
By the way, is there a way to remove them without
Section foo.
Let awfull_lemma : lot_of_awful_hypotheses -> awful_goal.
Proof.
 awful_proof.
Defined.
Lemma lemma: pretty_goal.
 pretty_proof_with_awful_lemma.
Qed.
End foo.
Thanks to all.
ah
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
