- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: andr� hirschowitz <ah AT unice.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] local definition in proof mode
- Date: Tue, 6 Apr 2010 21:17:48 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:date:from:to:cc:subject:message-id:references:mime-version :content-type:content-disposition:content-transfer-encoding :in-reply-to:user-agent; b=EMa+atEIHNESrVehjltETEhOSuedVIfj347TODrlm96M2rXV9rKTb6wUnwPOY9uTZk 01A+WFnfHEhRkI15U9PN5FyN0ejAYLHKPX3FZhgMIUtXR4XtkuxOu/cZHiqW2Ivejmok sy5/A07zIivic6RgyBcOqyTz4EtnkZxovPcXI=
On Tue, Apr 06, 2010 at 03:07:32PM +0200, andré hirschowitz wrote:
> Exactly. I just want to give a name to an awful term which I am unable to
> write although I am able to produce it in proof mode.
> > That makes me think of a maybe real solution, but I am not sure it works:
> > instead of a "pose (H := _ : P).", you should try a "Lemma H: P."
> No, this does not work because the local environment is not taken into
> account by this command (if my experiment is correct). Neither does
> Definition for the same reason.
An ugly option is to cut and past the current environment into a section.
Section ugly.
<paste here>
Definition... Defined.
End ugly.
JF
- [Coq-Club] local definition in proof mode, andré hirschowitz
- Re: [Coq-Club] local definition in proof mode,
Martijn Vermaat
andré hirschowitz
Stéphane Lescuyer
Guillaume Allais
- Re: [Coq-Club] local definition in proof mode, Pierre-Marie Pédrot
- Re: [Coq-Club] local definition in proof mode, Jean-Francois Monin
AUGER
andré hirschowitz
AUGER
- Re: [Coq-Club] local definition in proof mode, AUGER
- Re: [Coq-Club] local definition in proof mode, Pierre Courtieu
- Re: [Coq-Club] local definition in proof mode, Matthieu Sozeau
andré hirschowitz
Guillaume Allais
Stéphane Lescuyer
andré hirschowitz
Martijn Vermaat
