- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] local definition in proof mode
- Date: Tue, 06 Apr 2010 14:09:37 +0200
- Organization: ProVal
Le Tue, 06 Apr 2010 13:32:57 +0200, Stéphane Lescuyer <stephane.lescuyer AT inria.fr> a écrit:
I don't see what is the problem with assert, "assert (H : P)" is
basically "cut P" with the goals generated the other way, so it is
exactly what you asked for in your first message ; in particular, it
does add an hypothesis named H of type P in the second goal.
Note that assert can be used as pose as well : "assert (H := t)" will
act as "pose (H := t); clearbody H".
In fact I doubt that assert is what andre wishes, as I think andre wanted to say,
"assert (H: P)." produces an opaque term, and sometimes (it happened to me), we
should want a transparent term with usable definition.
Simulating would be:
Goal exists (b: bool), b = true.
1 subgoal:
(1/1) exists (b: bool), b = true
pose (b:= _: bool).
2 subgoals:
(1/2) bool
(2/2) exists (b: bool), b = true
exact true.
b:= true: bool
1 subgoal:
exists b.
b:= true: bool
1 subgoal:
(1/1) b = true
split.
Proof completed
Qed.
I know this example is stupid, but replacing "pose (b:=_ : bool)" with
"assert (b: bool)" won't make proof script succeed.
I already tried a "refine (let H := _ : P in _).",
as it allowed me to define H, I thought, "That's cool it works!",
but then for the second goal, when I saw a "H: P" instead of a "H:= ...: P", I was quite disapointed.
So I have no real solution; all I can advice is
whether to give a full proof term in an "assume"
or to do a Lemma/Definition/Theorem... of the type you wanted and save it with Defined instead of Qed
before and then use it.
That makes me think of a maybe real solution, but I am not sure it works:
instead of a "pose (H := _ : P).", you should try a "Lemma H: P."
After that you enter in a nested proof with same hypotheses as the one you have and once the proof is completed,
try to put a "Defined." instead of a "Qed.", then you should not have a "K := ...: P" in your hypothesis,
but you should be able to add it with "assume (K := H); unfold H in K.", and then continue as you wanted.
HTH,
Stéphane
On Tue, Apr 6, 2010 at 1:22 PM, andré hirschowitz
<ah AT unice.fr>
wrote:
no, if I experiment correctly.
assert generates two goals and does not forward to the second one the
formula produced for the first one.
Thanks for your answer.
ah
I think you are looking for the following?
assert (myname : mytype).
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
- [Coq-Club] local definition in proof mode, andré hirschowitz
- Re: [Coq-Club] local definition in proof mode,
Martijn Vermaat
andré hirschowitz
Stéphane Lescuyer
Guillaume Allais
- Re: [Coq-Club] local definition in proof mode, Pierre-Marie Pédrot
- Re: [Coq-Club] local definition in proof mode, Jean-Francois Monin
- Re: [Coq-Club] local definition in proof mode, AUGER
andré hirschowitz
AUGER
- Re: [Coq-Club] local definition in proof mode, Pierre Courtieu
- Re: [Coq-Club] local definition in proof mode, Matthieu Sozeau
andré hirschowitz
Guillaume Allais
Stéphane Lescuyer
andré hirschowitz
Martijn Vermaat
