Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?
chronological Thread
- To: Georgi Guninski <guninski AT guninski.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?
- Date: Thu, 19 May 2011 10:19:26 -0400
Georgi Guninski wrote:
Can I use this inductive type in a fixpoint (without declaring variable that
Inductive anything : Prop := d: (False->anything).
Yes, you can certainly write a [Fixpoint] definition over this type. It will have to be a degenerate fixpoint with no recursive calls, since your type definition is not recursive.
can i make a fixpoint of the sort:
Fixpoint fi1(a : True) : anything
If you can, you've found a bug in Coq, since it can be proved that no function of that type exists.
Lemma anything_False : anything -> False.
destruct 1; auto.
Qed.
Hint Immediate anything_False.
Goal ~(True -> anything).
intuition.
Qed.
"anything" appears not empty.
[anything_False] above establishes that [anything] is, in fact, empty.
- [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Georgi Guninski
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Adam Chlipala
Georgi Guninski
Adam Chlipala
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Lauri Alanko
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Georgi Guninski
Adam Chlipala
Georgi Guninski
