coq-club - Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?
chronological Thread
  • To: coq-club AT inria.fr
  • Cc: Lauri Alanko <la AT iki.fi>
  • Subject: Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?
  • Date: Thu, 19 May 2011 10:20:41 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:cc:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=WxV4ImFF+l8308uinNVrL3MParaAX+RD9ui1Q2SHaCNx9+MvgbTbEN/VfJvT7nxI2f Qe4PohNkrNmq9bbILrR6z+T7aiqx3sM8AHV5y+tdhHeWafGJXAWgC/SmDsG252RkXsE9 14MXgzP23cdy12PC7NpzG+jyBevB464usNSU8=
On Thursday 19 May 2011 09:09:24 Lauri Alanko wrote:
> On Thu, May 19, 2011 at 11:41:55AM -0400, Adam Chlipala wrote:
> > Georgi Guninski wrote:
> > >what is the formal definition of "empty"
> > A type [T] is empty if you can prove [T -> False].
> Sorry to nitpick, but the above might be a bit confusing to someone
> unfamiliar with the concept. Surely the formal (intensional)
> definition of "empty" is that a type [T] is empty if there are no
> closed terms [t] such that [t : T]?  Only due to the consistency of
> Coq is this (extensionally) equivalent with your definition above.
I'd formalize your definition as "~ inhabited T".  And it's trivial to prove
the two definitions are equivalent:
Lemma uninhabited_iff_empty: forall T:Type,
  (~ inhabited T) <-> (T -> False).
Proof.
firstorder.
Qed.
Daniel Schepler
