Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?
chronological Thread
- To: Georgi Guninski <guninski AT guninski.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?
- Date: Thu, 19 May 2011 11:41:55 -0400
Georgi Guninski wrote:
what is the formal definition of "empty"
A type [T] is empty if you can prove [T -> False].
Lemma l1: anything.
Proof.
constructor 1.
(* this passes without plug-ins *)
So would running [idtac]. The problem is that you haven't finished the proof. :P
- [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Georgi Guninski
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?,
Adam Chlipala
Georgi Guninski
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Adam Chlipala
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Lauri Alanko
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Georgi Guninski
Georgi Guninski
Adam Chlipala
