coq-club - Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?
chronological Thread
  • To: Adam Chlipala <adam AT chlipala.net>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?
  • Date: Fri, 20 May 2011 12:13:28 +0300
  • Header: best read with a sniffer
thank you all for the replies!
what is the human explanation of the "anything" class (i naiively would
expect it to be close to your lemma False_ind, may be wrong).
is any of these types empty or not (the wizard can't prove it any way):
Inductive AA : Prop := A0: BB->AA with BB : Prop := B0: AA->BB .
(suppose expressing disequation won't be possible).
On Thu, May 19, 2011 at 11:41:55AM -0400, Adam Chlipala wrote:
> Georgi Guninski wrote:
> >what is the formal definition of "empty"
> A type [T] is empty if you can prove [T -> False].
> >Lemma l1: anything.
> >Proof.
> >constructor 1.
> >(* this passes without plug-ins *)
> So would running [idtac].  The problem is that you haven't finished
> the proof. :P
